KB_fiver89 Posted September 9, 2016 Report Share Posted September 9, 2016 So I got the head gasket, new rings, put everything back together by the book, got spark but the car still will not start. It sounds sluggish while attempting to crank it up. Got gas, got spark but somehow that's not enough...... What am I missing??? Quote Link to comment Share on other sites More sharing options...
Bean Posted September 9, 2016 Report Share Posted September 9, 2016 Is rotor pointing at #1 with motor at tdc on compression stroke? Do you have a timing light to confirm it's firing in time? Do you have fuel pressure at fuel rail? (Or can you hear fuel pump cycles?) Rabin Quote Link to comment Share on other sites More sharing options...
SRDT Posted September 9, 2016 Report Share Posted September 9, 2016 You got gas coming to the injectors but can they open? Quote Link to comment Share on other sites More sharing options...
KB_fiver89 Posted September 16, 2016 Author Report Share Posted September 16, 2016 Motor is at tdc. Checked and checked again. Just got done removing cover and adjusting intake and exhaust valves all over again. Will attempt again in the morning Quote Link to comment Share on other sites More sharing options...
Bean Posted September 16, 2016 Report Share Posted September 16, 2016 You need to make sure it's TDC on the compression stroke, and the rotor is pointing at the #1 plug wire terminal - this ensures everything was reassembled properly and that the firing order timed correctly. If you have spark when cranking then it should fire on a puff of starting fluid which means you have a fuel issue. Rabin Quote Link to comment Share on other sites More sharing options...
SRDT Posted September 16, 2016 Report Share Posted September 16, 2016 +1 for the starting fluid. Quote Link to comment Share on other sites More sharing options...
