PeugeotPilot
Hugh's 1987 505 STX V6 Project
I hear you, Goce.  My personal life took some twists and turns that I won't get into here, and that is one of the main reasons for the lack of action over the last two years.  But things are getting back to "new normal" for me on that front, and it's time I turned some of my attention to my Peugeots again.
Having too many parts cars and projects around is definitely an albatross around my neck, so my first task was to define my vision for my car collection.  I did this over a matter of months, starting with a list of 30+ cars and eventually paring it down to seven cars and three motorcycles.  That got painful toward the end, as I was cutting some very desirable (to me, anyway) cars from the list.  But the bottom line is that I'm not rich and this modest collection is something I can realistically attain.
As it stands now, this consists of:
  • one 604 (heavily modified)
  • one 605 SV24
  • one 505 (the STX I already have)
  • two 406 Coupes (I'm starting a new build thread for these)
  • one Eagle Premier (the '88 LX I already have)
  • one Lincoln Mark V
  • one Kawasaki motorcycle (my current ZX9R)
  • two Yamaha motorcycles
Once I had the collection defined, the next step was to divest myself of everything not on that list.  So this is where I find myself now, although it's a long and ongoing process.  I've had lots of cars hauled away once I removed the usable parts, but I have a LOT of cars and I can't just throw them away if they have good parts on them.  As long as I'm moving forward with the disassembly and cleanup, that's the important thing.  In the meantime I have cars sitting in storage in the USA and the UK and I need to bring them home ASAP.  Bean has already been of great help in this regard.
One thing at a time, I guess!
Share this post
Small piece of advice: I'd skip the pop up sunroof - it would look super tacky on any Peugeot.  Just keep the original that doesn't work, or weld it over.
Share this post
I hear you, Mike, but the 505 sunroofs are problematic (the 604 design is much better) and I like the look of a glass panel rather than a metal one.  A fixed glass skylight would work too.  Bottom line is that I can shave some weight, simplify the car a bit, and still look up at the sky this way.  For what it's worth, the 406C sunroofs are much like this, although electric.  They tip up and slide back.
Like most other details, this one is not yet set in stone.
Share this post
The two possibilities I'm considering for this project are shown below, although it should be noted that the Phase I interior would be in dark blue like the Phase II dash.  The third picture shows yet another idea, using the Grant wheel with the Phase II dash.  This is going to be a tough call, as I like both dashboard styles.  The Phase I dash is most in keeping with the spirit of the Danielson V6 car, so that is the way I'm leaning at the moment.  But damn...it's a tough call.
Share this post
Bulky dashboard, have you taken a tape measure to it to see if you can fit one from a 405 or from a 406 ?
Share this post
I haven't, but the Phase I dash is pretty light and simple, plus really easy to remove and reinstall. Never considered fitting a 405 or 406 unit.  Interesting idea.  I bet it would be a lot of work though even if the width is the same.  I know that 604 dashboards, for example, are several inches wider.
Share this post
I quite like the series 1 dash, but like the series 2 dash more as it looks much more modern.  Personal preference.
As for plastic he’ll - it’s leagues better than the Volvo 850’s that came after it.
Share this post
The Danielson V6 was good in its day, but everything on the road these days is quicker.  I'd be inclined not to modify too much for maximum speed, because that can't be won.  Better to enjoy it as a homage to a sporting version of a nice 1980s comfortable sedan.
Share this post
Danielson did a good job with their V6 but the 2.8 193hp engine from the Alpine A310 V6 "Boulogne" was cheaper, they used a stock B28E volvo engine with -1mm on the heads, devil headers, Tagora SX intake manifolds matched to bigger carbs (Weber 46 IDA 3C) and that's about it.
Share this post
You are quite right, Mike.  My attitude is that there will always be someone out there with something faster.  There is a point of diminishing returns when it comes to the horsepower wars, and honestly what is the point?  The car will be plenty fast with around 200 bhp, and will still corner better in the real world than a lot of current cars.  That's good enough for me.  I think, as you say, an homage to the original Danielson V6, that respects the essential character of the 505, will be best.  At some point it's not a 505 anymore.
Thanks for your input, SRDT.  From what I've read, the Danielson V6 achieved its 195 bhp in part by running the 2.8L (2849 cc) version of the PRV engine to 7000 rpm.  That was with the standard 91 mm bore and 73 mm stroke.  The horsepower peak occurred at 6500 rpm as I recall.  I have a slightly different idea in mind, combining a 3.0L (2975 cc) Eagle Premier block and heads with the short-stroke crankshaft from a Renault 2.5 Turbo V6 (Z7U-T30).  This will give a displacement of 2568 cc and the same piston speed at 7000 rpm as the standard-stroke engine experiences at 6000.  The engine may or may not use forced induction - I haven't decided yet.  Turbocharging or supercharging is nice where I live because of the high density altitudes we get in southern Alberta, but I'm attracted to the idea of a high-revving NA engine for this car.
Apparently you can still get performance camshafts for this engine.  I will need to do some more research.
Share this post
Oh, i know what you want to make Hugh, you want that F1 engine. A stock peugeot ZPJ is very rev happy and smooth engine, and it has 93mm bore and 55mm stroke. About the time i was working on my Mi16x2 conversion, a very good friend that drives trucks had to transport a Alfa 155 full race car from greece to germany, we had to change trucks because the previous company has wrecked the trailer on a low bridge, so i got called and we fired it up let it idle for 10 min with the new owner's permission, that day i first time used an air shifter and that thing revved to 10 000 rpm maybe higher the engine looks very similar to ZPJ with that wide oil pan and 6 open throttle bodys, i drove it about 50 meters just to change thralers, but it was an eye opening experience, i'm sure it run on some race gas because made all of as cry. That thing revs up like nothing other and sounded incredible.
Share this post
The Alfa 155 DTM was using a 90° V6 on the later years, with a 90° V there was more room for the intake and the engine could be more compact than with the 60° angle from the stock Alfa "Busso" V6. The thing is that to make this bespoke race engine you needed to use the V angle and bore spacing of a real engine that had been fitted to one of your cars.
As it turns out for a few years Fiat had made Alfa and Lancia a single company and during those years the Lancia Thema 6V was using a 2.8 PRV V6... so Alfa homologated the 90° V and 108mm bore spacing from the PRV and then designed a race engine that was yet wasn't a PRV.
Share this post
I had no idea Thema's had a PRV engine, that may explain why SOME OF THEM HAVE 3-400 000 Km on them.
Share this post
