germsteel Posted February 28, 2014 Report Share Posted February 28, 2014 Hello all! I have been searching around for days for something like a Maintenance service schedule. Nothing in the files section here or over at the yahoo group. I only have the owners manual and I have never seen that maintenance record book people mention once in a while. So things like at what interval do I need to do a valve adjustment? Does anybody have a handy file with that information? Thanks much in advance. --G. Steel. Quote Link to comment Share on other sites More sharing options...
Bean Posted March 6, 2014 Report Share Posted March 6, 2014 Good question - but I don't think I've ever seen anything like that... Personally - I'm of the belief that routine maintenance depends more on the amount and type of use. The only thing relatively constant is oil change interval - but even then - if I've done lots of highway I'll usually extend the interval somewhat. I change brake fluid and coolant every 2-3 years, complete tune ups when I buy a car, then I maintain them as they show symptoms rather than change things on schedule. My one caveat is that I will often replace wear parts "while I'm at it" to save time and hassle later... (IE: If one one ball joint/tie rod is loose I replace both sides). Things like timing or resetting the TPS I do more regularly just to make sure the cars are running their best. Curious not to see if Peugeot ever listed their own schedule for these cars now. Rabin Quote Link to comment Share on other sites More sharing options...
bill Posted March 7, 2014 Report Share Posted March 7, 2014 I have the Peugeot Maintenance Record Book from 1989. My scanner is on the blink. I will try and get something typed up. It's funny, it has no mention of fuel injection adjustment (tps, afm, etc) which are so critical. There was something in the 83 manual that stressed not racing a cold engine, which is so important, particularly with the cast iron block and aluminum head and the temperature differential. Maybe that has been why i have been able to run mine without incident over the years. I let that oil temperature gauge tell me its okay to get on it if I want. The other thing missing is the idea of allowing the turbo to cool down after a hard run before shut down by idling for a minute or two. I know Saab books stressed that in their literature. It helps prevent the turbo from getting coked up. I saw that Saabs specs on their turbos were only at about 6 pounds psi. -Bill Quote Link to comment Share on other sites More sharing options...
bill Posted March 7, 2014 Report Share Posted March 7, 2014 Here are the main points from the maintenance manual: DRAIN AND REFILL Engine Oil 5000 miles Manual Transmission 30,000 Automatic 30,000 Hydraulic Systems (brake fluid) 30,000 Rear Differential 15,000 LUBRICATION Propeller Shaft Bearing 15,000 REPLACE Spark Plugs 30,000 Fuel Filter 60,000 Air Filter 30,000 CHECK AND ADJUST (IF NEC.) Valves 15,000 Kickdown 30,000 Air gap fan 15,000 Quote Link to comment Share on other sites More sharing options...
andrethx Posted March 7, 2014 Report Share Posted March 7, 2014 doesn't the haynes manual have a maintenance schedule, as well? Quote Link to comment Share on other sites More sharing options...
PeugeotFan613 Posted May 8, 2014 Report Share Posted May 8, 2014 AMSOIL has it on their page if you choose the fluid selection for that car. Quote Link to comment Share on other sites More sharing options...
