my3AWDgst Posted May 24, 2020 Author Report Share Posted May 24, 2020 Detective Coating is who I use, he’s a friend and they are located in Virginia. They have many different ways to get in touch and Justin would be the one to answer your question, I just send it and he gets it done for me. Quote Link to comment Share on other sites More sharing options...
Mike T Posted May 24, 2020 Report Share Posted May 24, 2020 Thanks, I think I will have this done. Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted May 25, 2020 Author Report Share Posted May 25, 2020 This was extremely ease to install but unfortunately they don’t clear 15” 205 GTI wheels, I end up ordering 3mm wheel spacers and same wheel bolt and washer kit as I did for rear wheels. Quote Link to comment Share on other sites More sharing options...
Goce Posted May 26, 2020 Report Share Posted May 26, 2020 Savo, the 607 i just fixed up has enormous breaks, the calipers are 2 piston, i know the disks won't work they are 5 bolt, but the caliper may bolt on 405 knuckle, the bracket bolt spacing looks identical, may be worth looking into, the 607 is an older model now and part prices are lower Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted June 22, 2020 Author Report Share Posted June 22, 2020 Lately I’ve noticed small oil stain where I park it and I keep everything clean and organized so this is totally unacceptable! Oil was definitely leaking and it was gear oil and it was coming from speed O ring/speedo adapter and luckily I had all parts in stock! Most of these parts are OEM and this is perfect reason why I keep/buy x2 or more parts for these cars and every time I use something out of my stock I immediately reordered whatever I used so I have it for next time. While I was at it I noticed steering rack boots stared to show cracks (everything was replaced when I was waiting for engine) so might as well replace them while I was in the neighborhood. Factory material on these boosts is very thin so they don’t last very long time, I also used good old MT90 oil and would not ever use anything else. Wait a minute mister! You had steering ram bushings in stock as well? I should also add that wheel spacers came in with new lug bolts and washers. Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted July 31, 2020 Author Report Share Posted July 31, 2020 Few weeks ago crankshaft vibration damper failed, luckily I was close to home and no damage to timing belt cover occurred. Took about two weeks ro receive parts from UK and took me only about an hour to replace it. She’s back in service Quote Link to comment Share on other sites More sharing options...
