eklo
2,941 profile views
eklo's Achievements
  1. Maxspeedingrods as a manufacture, We are renowned for our high performance racing parts which have been top of the line for a decade. Now we want to benifit our customers with more competitive price. We offer different types of High Performance Racing Parts bottom price give back to our customers, Bring The Performance Parts Back To Your Car! If you have made your decision and you want Racing Parts then i suggest Maxspeedingrods! Link: http://www.maxspeedingrods.co.uk/
  2. Fits: Renault Laguna Scenic Megane Trafic Master Kangoo Clio Volvo S40 V40 Nissan Primaster Opel Vauxhall Vivano Movano Mitsubishi Carisma Space Star - Well Balanced Turbo Price : £168.00 Link: http://www.maxspeedingrods.co.uk/renault-megane-laguna-dci-110hp-1-9l-gt1549s-turbo-turbocharger.html
  3. Maxspeedingrods as a manufacture, We are renowned for our high performance racing parts which have been top of the line for a decade. Now we want to benifit our customers with more competitive price. We offer different types of High Performance Racing Parts bottom price give back to our customers, Bring The Performance Parts Back To Your Car! If you have made your decision and you want Racing Parts then i suggest Maxspeedingrods! http://www.maxspeedingrods.co.uk/christmas.html http://www.maxspeedingrods.com/christmas.html
  4. Maxspeedingrods as a manufacture, We are renowned for our high performance racing parts which have been top of the line for a decade. Now we want to benifit our customers with more competitive price. To celebrate the WRC, We offer different types of High Performance Racing Parts bottom price give back to our customers, Bring The Performance Parts Back To Your Car! If you have made your decision and you want Racing Parts then i suggest Maxspeedingrods! Link: http://www.maxspeedingrods.co.uk/wrccelebration
  5. 1. Why turbos fail? – Diagnosis Investigate cause of original turbo failure before fitting replacement Most turbo failures are due to – Oil Starvation/Contamination, Electronics sensors, Air leaks over speeding turbo, or foreign matter entering compressor housing. Breather problems. 2. Rectify Malfunction Upon completion of diagnosis and conclusion of malfunction or component failure, either you must rectify the malfunction or replace the failed components with new components. Check for foreign particles. All BEFORE you fit the new turbo. 3. Replace Components Before fitting your new Turbo, you must Replace Components listed below OIL FEED PIPE (from engine to top of turbo), replace banjo bolts and oil drain Replace Turbo oil drain hose (check clear / check no damage to pipe) NEW OIL PUMP Oil and oil filter (correct grade as per manufacturers recommendation) Air filter Gaskets and washers, O rings Diesel Particulate Filter liquid level sensor topped up with fluid level 4. Clean or Replace Diesel Injectors – Clean, Test, Replace Air box and air intake hose to turbo (Pressure Test) Oil cooler/ intercooler/ hose, from turbo to intercooler (damage or air leak). Get Pressure Tested E.G.R VALVE – Check correct operation, clean or replace if necessary Breather system, cam cover (rocker cover) – check for blockage Clean Inlet/exhaust manifolds, check for carbon deposits/cracks/clean head faces/replace gaskets Ensure the exhaust and/or catalytic converter/diesel particulate filter (DPF) are not fully or partly blocked Before fitting Turbo – check no debris enters turbo, check all gaskets fit with gas tight seal Flush Engine 5. Fit and Test Turbo Check OIL PRESSURE is within manufacturers Tolerances Start engine and allow to idle for 3-5 mins before driving (do not let engine idle unnecessarily) Check for Oil/Gasket/Air Leaks, All OBVIOUS locations on engine Plug into diagnostic machine to check for any fault codes (rectify or repair as per diagnosis, before road test). A professional mechanic or turbo tuning shop is only recommended for the turbo fitting job of your car. The external influence on the failure of the turbo is not included in the warranty. And only with the turbo properly fitted, you will have your car return to the road earlier.
  6. Fit for:Universal T3 flange Turbo. Link: http://www.amazon.com/dp/B011NXY7Y2/ Features: 1.Brand new turbocharger turbine inlet flange gasket. 2.Fit with T3 turbo turbine inlet flange. 3.Material: quality steel. 4.Fit for:Universal T3 flange Turbo. Product Dercription: This quality steel 4 bolt gasket for T3 turbocharger turbine inlet flange. Packing includes: 1 x High Performance Turbo Gasket (as picture shows)
