Hi everybody!
This is my first post here. My name is Johanness in Portland Oregon. I just bought a '82 505S TD named "Pepé Le-Peugot"
He runs strong, and the manual transmission shifts well, with 120.200 miles on the odometer! The front brake calipers look a bit worn. And the pads are definitely low on meat and in need of replacement. I've ordered some from a parts wholesaler via e-bay, and they should be here soon. Here are my braking symptoms. When you come to a stop, after the engine has been at low revs, there is almost zero braking, and the pedal must be pumped. This pumping still may not yield much stopping power. However, if I downshift the manual transmission before a stop and the action increases the engine RPM, then there is more pedal, and more stopping power. The master cylinder is full, and the fluid in the cylinder looks to be of clean quality. The clutch works flawlessly as well. I don't suspect a hydraulic issues. I think it may be a vacuum leak? When I shut the car off, I hear a hissing. It's the vacuum system taking on air.
I wanted to ask the pro's here before I head to NAPA to replace all my main vacuum hose.
Thanks guys!
-J
PS: here is a pic!
